M4 MacBook Pro Teardown: What’s Inside and What’s Fixable?
1 Answer 0 Score |
What level of M4 Max warming is too much? |
2 Answers 0 Score |
How to physically disable microphones on MacBook Pro m4 |
2 Answers 0 Score |
Liquid damage on M4 Pro and it seems an IC chip needs to be replaced |
1 Answer 0 Score |
Does IFixit sell the following bits by themselves or as a special kit. |
Models
A3112 (Mac16,1 2024) M4 10 CPU/10 GPU, A3185 (Mac16,6 2024) M4 Max 14 CPU/32 GPU, A3185 (Mac16,6 2024) M4 Max 16 CPU/40 GPU, A3401 (Mac16,8 2024) M4 Pro 12 CPU/16 GPU, A3401 (Mac16,8 2024) M4 Pro 14 CPU/20 GPU
Background
Announced in October 2024—alongside the redesigned Mac mini and refreshed 2024 24" iMac—the quintessential MacBook Pro is updated once again with the next generation of Apple silicon: the M4, M4 Pro, and M4 Max chips. And, to support Apple Intelligence, base memory increases to 16 GB as standard across the board.
The 14" MacBook Pro shares many of the same features introduced in 2021 and 2023's MacBook Pros, including ProMotion HDR mini-LED displays, 1080p webcams with a display notch, full-size function keys, and the distinctive blacked-out keyboard. Base model M4 MacBook Pros, previously with one less USB-C port, are now in parity with their stronger M4 Pro and M4 Max siblings.
Starting at a $1599, the 2024 14" MacBook Pro is available in either Silver or Space Black.
Identification
Identify your MacBook Pro by the model number printed on its back cover.
You can also find the model number through macOS by choosing About This Mac from the Apple menu in the upper-left corner of the screen.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your MacBook Pro model.
The 2024 MacBook Pro features a large flat glass screen, thin black bezels, a "notch" cutout at the top of the screen, black keys, and an aluminum enclosure. There's a large gloss black Apple logo on the top shell and "MacBook Pro" engraved into the bottom case.
A MagSafe 3 charging port, two USB-C ports, and a headphone jack can be found on the left edge, with an additional USB-C port, HDMI port, and an SD card slot on the right.
Technical Specifications
Display
- 14.2" Liquid Retina XDR mini-LED display with True Tone; 3024 x 1964 pixels (254 ppi); ProMotion adaptive refresh rate (up to 120 Hz); HDR, P3 wide color gamut; 1000 nits sustained (indoor and outdoor), 1600 nits peak brightness
Processor
- Apple M4 10-core CPU, 16-core Neural Engine
- Configurable to M4 Pro 12-core CPU
- Configurable to M4 Pro 14-core CPU
- Configurable to M4 Max 14-core CPU
- Configurable to M4 Max 16-core CPU
Graphics
- Apple M4 integrated 10-core GPU
- Configurable to M4 Pro 16-core GPU
- Configurable to M4 Pro 20-core GPU
- Configurable to M4 Max 32-core GPU
- Configurable to M4 Max 40-core GPU
Storage
- 512 GB PCIe-based SSD, configurable to 1, 2, 4, or 8 TB.
Memory
- 16 GB of unified memory, configurable to 24, 32, 36, 48, 64, or 128 GB.
Wireless
- 802.11ax Wi-Fi 6E wireless networking; IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.3 wireless technology
Battery
- Built-in 72.4 Wh lithium-polymer battery
Dimensions
- Height: 0.61 in (1.55 cm)
- Width: 12.31 in (31.26 cm)
- Depth: 8.71 in (22.12 cm)
- Weight: 3.4–3.6 lbs (1.55–1.62 kg)
Ports
- MagSafe 3 charging port
- M4: 3× Thunderbolt 4 USB-C ports (40 Gb/s / DisplayPort / charging)
- M4 Pro & M4 Max: 3× Thunderbolt 5 USB-C ports (120 Gb/s / DisplayPort / charging)
- HDMI 2.1 port
- SDXC card slot
- 1× 3.5 mm headphone jack
